The PCB from the last post was part of a small panel. If you follow me on Twitter, I did post a photo on the whole panel there.
Next task: some extreme soldering. I did also found a low budget solution (not the brass nails) for the pins. I will write something about that when its soldered and ready. I think I will do the soldering today. There are also some changes in the software needed, but only some pin changes.
Alex
Awesome !
Put one aside for me when you do your next batch ;-)
Well, I do have more than enough. They sent me twelve.
