After seeing a talk about keyboards on a conference, I decided to try a different keyboard. While the keyboard itself was pretty bad -- one of those mechanical ones, loud, with huge travel and keys getting stuck if you don't hit them ideally vertically -- there was one thing I actually liked about it, and that's the fact that it didn't have a numeric keyboard. That lets you keep your mouse much closer and makes your hand less strained. I decided I need a tenkeyless keyboard. On to the Internet to look for one!
Several hours later I realized that nobody normal makes tenkeyless keyboards. They are the domain of the crazy mechanical keyboard crowd, possibly because that lets them save $100 on additional switches. It's absolutely impossible to find a good, wired, scissor-key, tenkeyless keyboard, no matter the price range. Sigh. That means I have to make my own.
Unfortunately, scissor keys are hard to get (and even harder to make, I suppose). So I will need some kind of the "mechanical" switches (they are actually electrical switches, "mechanical" just sounds cooler) that don't have such a large travel and don't get stuck. Maybe like the ones I had in some of my older computers? Hmm, do I have some old computer keyboards?
Turns out that I had one, that I saved from trash precisely for the switches. I wanted to make a stenotypist keyboard with them (and use Plover), but now that will have to wait. They keyboard is quite nice and heavy, but a little bulky.
Some searching revealed it's Chicony KB-5161 with Alps SKCM Blue switches. Whatever. Let's look inside.
It should be relatively easy to cut off the numeric keyboard part of the plate, and then make a new chassis for the whole thing.
deʃhipu
