I never used stencils to apply soldermasks before (Well, I also always milled my boards which limited the size of the smd components to a size that is still pretty easy to hand solder, so I'm very new to boards in this quality).
Since I use a TQFP Packaged ATTiny, I thought it would be a good idea to produce some stencils for the board.
My first thought was to mill them myself from some thin aluminium sheets, but I quickly realized that I dont have mills small enough and the only way to produce holes small enough would by to etch them or use a laser cutter. Since I do not own a laser cutter and have no idea if it is even possible to etch aluminium, I searched online for cheap and easy services.
I quickly found OSHStencils and was quite suprised from the fammiliar interface (well, exactly what you expect from the name :) ). I uploaded my *.brd file and ordered a set of stencils. Lets see how they turn out when they arrive.
take a look at this for diy stencils - http://lowpowerlab.com/blog/2013/02/11/diy-smd-metal-stencils-the-definitive-tutorial/
Thanks for the link. I just had a look on google. I didn't think that it is that easy to get muriatic acid in Germany. We always have quite strict constraints when buying "potentialy dangerous" chemicals.
Although I don't think I will do my stencils at home in the future, I'm still going to buy some acid just for the sake of learning and trying it out.
