I'm trying to document the API here. This will change often.
GET /projects/example/active
{"id": "123",
"priority": 0 to 3,
"description": "string",
"details": "a longer string",
"status": "[todo,current,done]",
"due": "2015-10-30T23:01:47Z",
"assignee": "[userid? for future use.]"}
]POST /projects/example/create
{"description": "string",
"priority": 2,
](returns the database - like .../active)
POST /projects/example/123
"priority": 2,
Everything above this line is implemented.
GET /projects
["example"]POST /projects/example{"description": "blah"}{"status": "[unchanged|created|success|failed]"}
alpha_ninja
