ShrinkDuino UNO
Pocket sized ARDUINO UNO Clone
My aim was shrinking the Arduino UNO to minimum size by simultaneously maintaining it's fundamental functionality and pinout.
The result is the ShrinkDuino UNO with ATMega328P and CH340G as USB-serial interface - well known from other Arduino UNO clones.
With a size of approximately 4.3 x 2.2 cm (without USB plug) it fits direktly to the USB port of a PC.
shrinkduino_manufacturing_data.zip
Gerber files for PCB production
x-zip-compressed - 20.43 kB - 01/09/2017 at 19:30
Download
shrinkduino_DesignSpark.zip
Project files for use in DesignSpark PCB
x-zip-compressed - 62.08 kB - 01/09/2017 at 19:29
Download
Zilvinas LY2SS wrote 10/07/2017 at 17:59 • point
What about connectorless USB PCB plug ?
K.C. Lee wrote 01/10/2017 at 00:21 • point
May be it is an optical illusion, the connector spacing of the top two connectors in your picture does not look like they fall on a 0.1" grid to me.
Lexcis wrote 01/10/2017 at 08:55 • point
You mean the gap between IO-pins 7 and 8? It's not 0.1" grid, but it's the same like on the Arduino UNO.
deʃhipu wrote 01/09/2017 at 20:28 • point
What is the advantage over Arduino Nano?
Lexcis wrote 01/09/2017 at 21:25 • point
You can directly plug it into the USB-port :) And the pinout is the same like on Arduino UNO. That makes it easier to wire UNO shields to it. Admittedly a disadvantage are the missing LEDs for serial RxD and TxD.
deʃhipu wrote 01/09/2017 at 23:20 • point
I see. So from the practical point of view, I would need to get under my desk to plug it in, and I can't plug it into a breadboard because of the weird UNO half-pin header spacing.
Lexcis wrote 01/10/2017 at 09:06 • point
Nobody said it's the perfect solution for everyone. But for some of my projects it's more practical than wiring an UNO by USB cable. Maybe it's because I don't use breadboards and I mainly use my notebook instead of a desktop computer.
deʃhipu wrote 01/10/2017 at 09:50 • point
It's always great to have more choice! Good luck with the project!
Lexcis wrote 01/09/2017 at 19:35 • point
Hi, thanks for your hint. I just used this switch because I had it laying around in masses and it was very cheap.
