Since the actual installation also needs a 32-Bit UEFI comaptible bootloader, installing Arch is not as trivial. Again, after some search, I found a Medium Post that descibes exactly that. The only thing missing was using grub-mkconfig to make a new GRUB config.
You can see the way I did it in the instructions of this project.
