Good enough for now!
A project log for Light Alarm Clock
Standalone alarm clock that will fade a light on and then back off.
gannongannon • 11/18/2015 at 01:52•0 Comments
The 3.3V logic from the NodeMCU wasn't enough to fully turn on my FET, so I have rigged up a simple level shifter using a diode and resistor. The light is actually fairly bright now rather than the dim glow it used to be.
