The latest and greatest motor mount.
I have two motor mounts that each go through the original isolating rubber mounts. I was happy to have the opportunity to weld something that wasn't thin sheet.
These plates were cut with a CNC plasma cutter. It was nice to use the fancy equipment, but I think I could have gotten it cut out in less time with a bandsaw. I learned from this experience to bring more material than you really need. I had a lot of trouble with the plate shifting when the cutter touched off.
This mount bolts to the motor right next to the high voltage input, thus the curved side plates.
Adam Curtis
