We are working on a new version of the Memtype, this time we will call it Memtype Lite. It wil have the same features as Memtype with the following improvements:
- Increased Credentials Size
- Better OS compatibility, Windows, Linux, Mac.
- Add / Delete / Modify credentials and device configuration using a command line interface through serial port.
- One side PCB with USB form factor to be embedded into a plastic case.
- Firmware Update.
In order to have a prototype to play with, we ordered 5 boards from PCBWay. The boards arrived in a week by selecting DHL shipping method. If you need quick turnaround at very low price PCBWay is your choice.
![PCBWay package PCBWay package](https://cdn.hackaday.io/images/3748761548107944120.jpg)
This is how the package looked, PCBWay kindly added a Merry Christmas message on the box. After opening the package we checked the dimensions of the boards within the USB case.
![Memtype PCB with USB case Memtype PCB with USB case](https://cdn.hackaday.io/images/6709971548108502493.png)
The PCB boards manufactured from PCBWay looked very nice, the silkscreen was very good, they made a castellated hole on the USB connector and everything was according the gerber files provided.
