After my little disaster where a blown ESC took out the entire ESC board and the current resistor on the main daughter board, I've decided a bit of protection might be in order (better late than never I suppose). So, as well as the polyfuses on the new ESC board, I've added a polyfuse between the battery and everything else. You can see it inserted into the V+ line below.
