Hackaday.io Hackaday.io
Sign up Log in
32x64 RGB NTP Clock
32x64 RGB LED NTP Client Clock Driven By ESP8266 And STM32F103C8
abdullbasitAbdullbasit
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
0 comments
469 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.7k
0
469
4
Team (1)
  • abdullbasitAbdullbasit
Join this project's team
  • Source , schematic and pcb design
hardware
ongoing project
STM32 ESP8266 clock ntp client 32x64 rgb led
This project was created on 11/06/2015 and last updated 8 年前.
Description
This is a very simple RGB Led clock demo that uses the new comer ESP8266 as ntp client (To update the time at start-up , Thus no backup battery is needed in case of power shutdown)connected to the driver MCU (STM32F103C8T6) via USART1 , The ESP8266 is flashed by nodeMcu Lua and simple ntp client program (ntp.lua) that is attached in the link below.
All source code , schematic and PCB Layout(Using Labcenter Electronics Proteus 8.1) can be found here:
https://www.dropbox.com/sh/ab7oqd44r9min7f/AADWkQegkrM0wEOov0b5DSzIa?dl=0
Details
Log In/Sign up to comment
Sign up with Github
OR
The 2018 Hackaday Prize
Tix Clock Implemented In a Gem Mine Diorama
Project Owner Contributor
Tix Clock Gems
chris-chungChris Chung
A quick digital clock based on a Teensy 3.1 and some LED matrices
Teensy Clock
rich-hRich H
A very-modern take on the popular late-80s soviet clock.
Elektronika 7-06 clock replica
makufelis-xyzmakufelis-xyz
This project demonstrates how to build a large, easy-to-read LED digital clock using inexpensive and widely available components.
3 Inch LED Digital Clock Project PIC16F628A
youkito1991youkito1991
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "32x64 RGB NTP Clock", please tell us the reason.
Send message
Remove Member
