The Messy80 has 32kb of EEPROM and 32kb of RAM, 8 interupts and 8 separate outputs to select external IO interfaces with up to 32 addresses each.
The board has header that expose the necessary input/outputs to expand the functionality of the Messy80.
On board there is a 16C550 UART and a UART to USB chip which is used as the standard interface.
The monitor program is written for zasm.
This is what the serial monitor looks like right now:
I am currently using cool-retro-term and picocom for added effect.
Memory layout:
| Start | End | Description |
| 0x0000 | 0x7FFF | ROM, Monitor |
| 0x8000 | 0x83FF | RAM, Reserved for monitor |
| 0x8400 | 0xFFFF | RAM, For whatever, as long as it doesn't collide with the stack* |
* The stack is set up at 0xFFFF and grows downwards.
TODO:
Start building circuits on the breadboard to interface with the Messy80
Connect a CF-card to the bus and write a simple flat filesystem.
Oliver.D
Lee Hart
J.B. Langston
Steve Smith
