• Operational.
    Matthew (mirage335) Hines • 01/07/2016 at 02:40 • 0 comments
    Finally, CNC millling, laser cutting, and multi-material extrusion, have all been done with this machine. However, the tool platforms obstruct a bit too much of the build area when mounted simultaneously. Check out MightyTool, the compact multi-tool platform also intended for use with more typical 3D printers. Custom 250W milling spindle included, built into aluminum extrusion.
