Finally, CNC millling, laser cutting, and multi-material extrusion, have all been done with this machine. However, the tool platforms obstruct a bit too much of the build area when mounted simultaneously. Check out MightyTool, the compact multi-tool platform also intended for use with more typical 3D printers. Custom 250W milling spindle included, built into aluminum extrusion.
