This is the Processing code i used in the second demo video demonstrating the rotary disks.
It is receiving the Teensy data from the serial port (for communication syntax, see Arduino code in the other project log entry).
The wheel resolution (see LEDMode in Arduino code) is being controlled here.
All the values are being scaled.
// ***** wheelController Software *****
// ******** Jan Godde, 2015 ********
// PROCESSING RECEIVE SKETCH FOR arduinoSendWheelsMore SKETCH
// USING PHASE VOCODER IN PD IN soundWheel.pd SKETCH
import processing.serial.*;
import org.puredata.processing.PureData;
PureData pd; // don't forget: expr operator seems not to be working with pdp5!
final int REVOL = 308; // resolution optimized: 4 x (77 black bars)
Serial myPort;
String thisString = "0";
int[] splitString = {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1};
int LEDMode;
int wheel2Mode;
float pos1, pos2;
float ribbon1, ribbon2, fader1, fader2, fsr1, fsr2;
float knob1, knob2, knob3, knob4;
float lefttouch, righttouch, mono, wheeltouch1, wheeltouch2;
float[] inputValue = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; //fader, pressure, knobs, 2 wheels
float[] touch = {0, 0, 0, 0, 0}; //2 touch ducking - 1 touch mono (middle) - 2 wheel touch
float[] ribbon = {0, 0};
void setup()
pd = new PureData(this, 44100, 0, 2);
pd.openPatch("wheelSound.pd");
pd.start();
size(1200,700);
background(0);
noStroke();
smooth();
LEDMode = 0;
wheel2Mode = 0;
String portName = Serial.list()[4]; // N° 4
myPort = new Serial(this, portName, 57600);
//myPort.bufferUntil('\n');
myPort.clear();
void draw()
myPort.clear();
lefttouch = constrain( map(touch[0], 1000, 5700, 0, 1000), 0, 1000 );
righttouch = constrain( map(touch[1], 1050, 5700, 0, 1000), 0, 1000 );
mono = constrain( map(touch[2], 1000, 5700, 0, 1000), 0, 1000 );
wheeltouch1 = constrain( map(touch[3], 1500, 6500, 0, 1000), 0, 1000 );
wheeltouch2 = constrain( map(touch[4], 1500, 6500, 0, 1000), 0, 1000 );
fader1 = constrain( map(inputValue[0], 0, 1023, 0, 1000), 0, 1000 ); //fader1
fader2= constrain( map(inputValue[1], 0, 1023, 0, 1000), 0, 1000 ); //fader2
fsr1 = constrain( map(inputValue[2], 0, 700, 0, 1000), 0, 1000 ); //fsr1
fsr2 = constrain( map(inputValue[3], 200, 700, 0, 1000), 0, 1000 );//fsr2
knob1 = constrain( map(inputValue[4], 0, 1023, 0, 1000), 0, 1000 ); //knob1
knob2 = constrain( map(inputValue[5], 0, 1023, 0, 1000), 0, 1000 ); //knob2
knob3 = constrain( map(inputValue[6], 0, 1023, 0, 1000), 0, 1000 ); //knob3
knob4 = constrain( map(inputValue[7], 0, 1023, 0, 1000), 0, 1000 ); //knob4
ribbon1 = constrain( map(ribbon[0], 450, 750, 0, 1000), 0, 1000 );
ribbon2 = constrain( map(ribbon[1], 450, 750, 0, 1000), 0, 1000 );
drawWheels(inputValue[8], inputValue[9], wheeltouch1, wheeltouch2);
pos1 = constrain( map(inputValue[8], 0, ((LEDMode+1)*REVOL), 0, 1000), 0, 1000 );
pos2 = constrain( map(inputValue[9], 0, ((LEDMode+1)*REVOL), 0, 1000), 0, 1000 );
// send all values from 0...1000
pd.sendFloat("vol1", (float)fader1); //fader1
pd.sendFloat("vol2", (float)fader2); //fader2
pd.sendFloat("pvrev1", (float)knob2); //knob2
pd.sendFloat("pvrev2", (float)knob3); //knob3
pd.sendFloat("drywet1", (float)knob1); //knob1
pd.sendFloat("drywet2", (float)knob4); //knob4
pd.sendFloat("pos1", (float)pos1); // wheel 1 position
pd.sendFloat("pos2", (float)pos2); // wheel 2 position
pd.sendFloat("transpose1", (float)fsr1); //fsr1
pd.sendFloat("transpose2", (float)fsr2); //fsr2
pd.sendFloat("touch7", (float)lefttouch);
pd.sendFloat("touch9", (float)righttouch);
pd.sendFloat("touch8", (float)mono); // "mono" channel cross-talk
pd.sendFloat("wheeltouch1", (float)wheeltouch1); // wheel touch 1 & 2
pd.sendFloat("wheeltouch2", (float)wheeltouch2);
pd.sendFloat("wheel2mode", (float)wheel2Mode); // scratch mode on/off on wheel 2
pd.sendFloat("ribbon1", (float)ribbon1);
pd.sendFloat("ribbon2", (float)ribbon2);
void drawWheels(float pos1, float pos2, float touch1, float touch2)
background(0);
noFill();
//fill(255);
strokeWeight(4);
stroke(255);
ellipse(310, 350, 500, 500);
ellipse(890, 350, 500, 500);
strokeWeight(20);
pushMatrix();
translate(310,350);
rotate(radians((pos1/(REVOL*wheelResolution()))*360));
stroke(55+((touch1/1000)*200));
line(0,0,0,-220);
popMatrix();
pushMatrix();
translate(890,350);
rotate(radians((pos2/(REVOL*wheelResolution()))*360));
stroke(55+((touch2/1000)*200));
line(0,0,0,-220);
popMatrix();
void serialEvent (Serial myPort){
thisString = myPort.readStringUntil('\n');
if (thisString != null){
thisString = trim(thisString);
splitString = int(split(thisString, ' '));
if (splitString.length == 19){
inputValue[0] = int(splitString[0]);
inputValue[1] = int(splitString[1]);
inputValue[2] = int(splitString[2]);
inputValue[3] = int(splitString[3]);
inputValue[4] = int(splitString[4]);
inputValue[5] = int(splitString[5]);
inputValue[6] = int(splitString[6]);
inputValue[7] = int(splitString[7]);
touch[0] = int(splitString[8]);
touch[1] = int(splitString[9]);
touch[2] = int(splitString[10]);
touch[3] = int(splitString[11]);
touch[4] = int(splitString[12]);
inputValue[8] = int(splitString[13]); // wheel left position
inputValue[9] = int(splitString[14]); // wheel right position
LEDMode = int(splitString[15]);
wheel2Mode = int(splitString[16]);
ribbon[0] = int(splitString[17]);
ribbon[1] = int(splitString[18]);
float wheelResolution(){
switch(LEDMode){
case 0:
return 1.0;
case 1:
return 2.0;
case 2:
return 3.0;
case 3:
return 4.0;
case 4:
return 5.0;
return 1.0;
Jan Godde
