A quick test of the motor controller. I had to be slow decelerating to avoid feeding too much power back into the power supply. This is an advantage when using a battery as it allows the battery to be charged during braking:
A project log for Self balancing skateboard
A skateboard style mode of transport which balances on two wheels in the centre
