Three things I could rant about:
- I forgot that the Arduino is 3.3V and 8MHz
- the OLED displays I once bought had no reset circuit - fixed by adding a 10k resistor and 100nF cap, see: http://rayvenn.alnet.com.ua/2013/08/crius-oled-display-fix/
- the mounting holes of the pcbs are designed off center from the joystick - fixed case with dremel
