Finally testing the enclosure design on 1/8in clear acrylic using our little 40W laser cutter in the shop.
We've been playing with the overall dimensions a bit, and found that 6.5in is a bit small on the back to fit the two panel-mount connectors and the Pi. It seems that we'll settle for a 6.75in square with a 1/4in overhang for the footprint of the case!
More coming soon!
