I made a video for the progress on the Cruise Control. Unfortunately its not finished yet, I still need to find the right code.
Code:
// Arduino Leonardo Rev3.0
// This code is for all Scania 4-Series
// ACC HID control for ETS2
void setup() {
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
// the loop routine runs over and over again forever:
void loop() {
// read the input on analog pin 0:
int analogValue = analogRead(A0);
// print out the value you read:
Serial.println(analogValue);
delay(100); // delay in between reads for stability
if (analogValue > 870 && analogValue < 890) // read the analogue input into variable analogValue
//ACC is in the OFF Pos
Serial.print("ACC OFF");
delay(1);
else
if (analogValue > 950 && analogValue < 965)
//ACC is in the ON Pos
Serial.print("ACC ON");
delay(1);
else
if (analogValue > 985 && analogValue < 995)
//ACC is in the ON Pos and RET is Pressed
Serial.print("ACC ON+RET");
delay(1);
else
if (analogValue > 1000 && analogValue < 1011)
//ACC is in the ON Pos and RES is Pressed
Serial.print("ACC ON+RES");
delay(1);
else
if (analogValue > 1012 && analogValue < 1025)
//ACC is in the ON Pos and ACC is Pressed
Serial.print("ACC ON+ACC");
delay(1);
// Jeroen van der Velden
// https://hackaday.io/project/8448-real-dashboard-truck-simulator
What I need:I have 3 switches:
1: Acc (Cruise Control Accelerate speed)
2: Ret (Cruise Control Retrieve speed)
3: Res (Cruise Control Resume from last speed)
I have one toggle Switch:
Cruisecontrol ON/OFF
I want the ON/OFF to toggle a keyboard character "c" when used.
I want button 1 to send a "7"
I want button 2 to send an "8"
I want button 3 to send a "9"
The code should pause after each change (no loop). The 10k Restistor is a pull-up resistor for debounce.
There is an Arduino Ohm meter tutorial so that might be a start.
