So close thanks to member OUTSIDER on the Arduino Forums!
The code below will tell us the handle position and difference between all positions just like in a real Scania!
Final challenge; keyboardPrint`s!
unsigned long startTime, endTime = 1000;
byte handlePos, oldHandlePos, currentPos;
int8_t diff;
int val;
bool posSent = true;
void setup()
Serial.begin(9600);
val = getAnalog();
Serial.print("\nCurrent handle position = ");
Serial.print(handlePos);
Serial.println("\n\n");
currentPos = oldHandlePos = handlePos;
void loop()
val = getAnalog();
if(handlePos != currentPos)
startTime = millis();
currentPos = handlePos;
posSent = false;
diff = 0;
if(!posSent && millis() - startTime > endTime)
Serial.print("Handle Position = ");
Serial.print("\t");
diff = handlePos - oldHandlePos;
Serial.print("Difference = ");
Serial.println(diff);
posSent = true;
int getAnalog()
val = analogRead(0);
if(val < 187) handlePos = 0;
else if(val < 350) handlePos = 1;
else if(val < 518) handlePos = 2;
else if(val < 679) handlePos = 3;
else if(val < 861) handlePos = 4;
else handlePos = 5;
return val;
// by Jeroen van der Velden
// https://hackaday.io/project/8448-real-dashboard-truck-simulator
// Credits to Arduino Forum member "OUTSIDER"
