The system is coming together nicely :-)
The two PCB have been soldered and tested, nothing special, except that I should have rotated the 4017 by 180°...
Some SMD parts are needed, for example the LVC1G14:
The cast aluminium box is solid and waterproof. A matching RJ45 plug completes the system:
Who wouldn't want to press these lovely buttons ?
Soon you'll enjoy them in Vallensbaek !
Yann Guidon / YGDES
Scotch tape... :D
yup, i did not plan a proper fixation in the box and it's better to avoid electrical contact, right ? :-)
