A small PCB update, the SMAs now have a more appropriate orientation with centre pins on top of the board. Also osc decoupling cap moved slightly.
A project log for HF receive converter for RTL-SDRs and similar
Converts 0 - 30 MHz up to 50 - 80 MHz. Allows HF(shortwave) reception on RTL-SDRs and the like. A square inch project entry
