I have now implemented the two dimensional version of Trinity Net, Trinity Small Net, into an MPPA type environment. It's using the Dual Core Small Net Complex so for every node there are two Trinity cores. I am still yet to check through to ensure there are no bugs introduced by the change. Note I still have Trinity Net available.
I decided to try out running a program on a 49 node array and took a timing of how long it took to simulate 400 us. This came out as about 2 hours, which means I am still compute bound for a large array and resource bound as to the possibility of getting into hardware.
I am going to use a four by four array for testing in sim and then cut it back for FPGA testing for the large board.
