Early Branch ?
A project log for Trinity Core and Net
A 32 Bit Variable Length Instruction Set Core and Transputer Like Comms Network
andre-powellAndre Powell 09/16/2016 at 23:020 Comments
I have now created or rather put together the first cut of a Branch prediction block.
It uses a simple method that I found in a book some time ago.
You don't decode the instruction, you just have to remember the PC and where it went. You have a small cache to store the PC and where it's off to.
Now to see if it compiles and then test it!
