Too Big !
A project log for Trinity Core and Net
A 32 Bit Variable Length Instruction Set Core and Transputer Like Comms Network
andre-powellAndre Powell 07/15/2016 at 17:210 Comments
I ran up the multi ore testbench after getting all the libraries including the Memories compiled up.
Unfortunately the resulting wave file is of the order of 330MB after 10 us of run.
The problem is that ALL signals are included in the waves and as far as I am aware there is no way to select a sub group.
When GTKWave attempts to open such a file a segmentation fault eventually happens.
The next step is to transfer the compilation scripts and put them on the Linux box to se if that version will fare better.
