Today I have 19 projects on hackaday (even after I asked al1 to take ownership of #PICTIL) and I need to automate more !
So I added more features, parallelised the script a bit, scraping more pages and more conditional execution to adapt to each project (some have building instructions, others have logs, some have nothing...)
So here is the new version in its whole ugliness ! (remember kids, don't do this at home, yada yada)
#!/bin/bash
MYHACKERNUMBER=4012 # Change it !
fetchproject() {
mkdir $1
pushd $1
# Get the main page:
wget -O main.html "https://hackaday.io/project/$1"
grep '<div class="section section-instructions">' main.html &&
wget -O instructions.html "https://hackaday.io/project/$1/instructions/" &
# Get the images from the gallery
wget -O gallery.html "https://hackaday.io/project/$PRJNR/gallery"
grep 'very-small-button">View Full Size</a>' gallery.html |\
sed -e 's/.*href="//' \
-e 's/".*//' |\
tee images.url
[[ "$( < images.url )" ]] && ( \
mkdir images
pushd images
wget -i ../images.url
popd
# Get the general description of the project
detail=$(grep 'show">See all details</a' main.html|sed 's/.*href="/https:\/\/hackaday.io/; s/".*//')
if [[ "$detail" ]]; then
echo "getting $detail"
wget -O detail.html "$detail"
# list the logs:
grep 'https://hackaday.io/project/.*/log/' detail.html|\
sed -e 's/.*<strong>Logs:<\/strong>//' \
-e 's/<br>/\n/g' \
-e 's/<p>/\n/g'|\
grep '^[0-9]*[.] <a ' |\
tee index.txt
sed 's/.*href="//' index.txt |\
sed 's/".*//' |\
tee logs.url
if [[ "$( < logs.url )" ]]; then
mkdir logs
pushd logs
wget -i ../logs.url &
popd
fi
fi
popd
######### Start here #########
DATECODE=$(date '+%Y%m%d')
mkdir $DATECODE
pushd $DATECODE
wget -O profile.html https://hackaday.io/hacker/$MYHACKERNUMBER
# List all the projects:
wget -O projects.html https://hackaday.io/projects/hacker/$MYHACKERNUMBER
#stop before the contributions:
sed '/contributes to<\/h2>/ q' projects.html |\
grep 'class="item-link">' |\
sed -e 's/.*href="\/project\///' -e 's/".*//' |\
tee projects.names
ProjectList=$( < projects.names )
if [[ "$ProjectList" ]]; then
for PRJNR in $ProjectList
do
( fetchproject $PRJNR ) &
done
else
echo "No project found."
fi
popdI still have to make a better system to save the logs, I have an idea but...PS: it's another quick and dirty hack, so far I'm too lazy to look deeply into the API. It's also a problem of language since bash is not ... adapted. Sue me.
OTOH the above script works and does not require you to get an API key.
Yann Guidon / YGDES
