The layout of the site has changed and I didn't see that my regular backups didn't work well.
Until today.
I'm updating the pattern matching, please stay tuned...
pages: check. Nor sure how to deal with more pages though but the limit is not yet reached.
projects: a few things have been broken, let's investigate step by step.
- main project page: OK (though could still get some more cleanup)
- components: OK
- instructions: OK
- images/gallery: OK
TODO:
- ensmarten wget (inside a function/procedure) so it detects failures and errors that are not reported as 404 by the server !
- cleanup the HTML files to remove most of the HaD formatting and boilerplates. AT LEAST remove that huge HaD logo in ASCII art that is easily compressed but takes a lot of room anyway... (done with a grep oneliner)
- Test if a file has already been downloaded and remove previous identical versions of the past backups... (meaningful for the big files !)
lun. sept. 26 00:50:45 CEST 2016 : New version online ! It took only 8h to polish it but it's well worth it. UPDATE YOUR SCRIPTS !
Yann Guidon / YGDES
