A quick heads-up that I finally found the time to update the wESP32.com website with new information related to the changes in revision 7 such as 16 MB of flash and RTL8201 Ethernet PHY. The product brief has also been updated, make sure to check the code examples to see the changes you may need to make to your software for this revision!
Patrick Van Oosterwijck
