Since one of my design goals for this synth is that it be portable, it obviously needs a to operate from a battery pack. There are a lot of good designs for lipo battery packs and charging systems out there. Also quite a few breakout boards and components from the hobbyist suppliers we all know. But since I have no idea what the final current requirements for this system are, I wanted something pretty quick and dirty (and inexpensive) to get things rolling. And I found just the thing.
![](https://cdn.hackaday.io/images/2352581524465880692.jpg)
Pictured is one of those "Power Bank" battery packs that is designed to recharge your phone when you are not near your charger. Most people probably see just that. I saw, however, a 2200mAh Lipo battery and a charge controller for $6.45 from Amazon. It would have to be reworked though. The output needs to be provided across a pair of RJ-11 connectors which is what all of my modules will be using. I guess you could hack some sort of adapter cable together to make it work, but that certainly would not be sufficiently rugged, and I wanted the battery pack to look like the rest of the modules in the set.
![](https://cdn.hackaday.io/images/3186901524466790260.jpg)
Taking the unit apart was trivial. The cover snapped off easily revealing a single battery cell, and a small circuit board that held the charge controller. The board has a full sized USB socket that provides voltage out, and a mini-USB socket for charging the battery.
I wired the two RJ-11 jacks in parallel, then wired the power leads to the back of the full sized USB connector on the controller board.
![](https://cdn.hackaday.io/images/1803641524467160932.jpg)
Granted, this is a terribly simple hack. I've included it for two reasons; First, I earlier published that the first module I'd build is the power supply so I thought I should mention it. But second, and more importantly, just wanted to point out that if you're building some form of portable project that needs 5 volts, there's no need to reinvent the wheel. These cell phone battery packs come in all sorts of capacities, and are really a bargain considering what you get!PARTS USED:
PARTS USED:
- Enclosure https://www.digikey.com/product-detail/en/hammond-manufacturing/1551KTBU/HM1146-ND/2094884
- LB1 2200mAh 5V Power Bank https://amzn.to/2qYee80
- 6P4C Verticle RJ11 Jacks https://amzn.to/2HX9LdS
