Thoughts about microcontroller
A project log for tinyKey
One key keybaord
alexAlex • 03/15/2018 at 22:14•0 Comments
I did a little bit of research which microcontroller I should use. Becuase using USB on an microcontroller is new to me it should be also well documented. And to fit this project It  should be relative small.
First I thought about the Atmegegas with USB (32u4, 32u2...), which are still a backup possibility, bur so far i Will concentrate more on Microchip's PIC16F1454 . Resons for that are:
