I am putting a variation of the design up on github - https://github.com/FyberLabs/usb-motor/
It is a specific application that was requested awhile back. I will be making a few variants including a powerbank, drone charger, and a brushless controller similar to this one. The design is a bit larger, but it can be shrunk down to about the same size. The original design would require 12-20V from the USB source. Now it will be able to accept 5-20V for 1-4 cells in the design. The design can obviously be reduced by a specified cell count and application.
Chris Hamilton
Hi Would like one of this board pre built, Do you have any for sale?
