Modernize and modularize the Arduino Uno platform. Make a processor daughter board platform with height below the normal shield headers. Add voltage level shifters as appropriate for the processor.
Create a better USB to serial/SWD programming and debugging capabilities using Blackmagic Probe firmware. (Off board programming support with a connector as well.)
Support common WiFi, Bluetooth, and other microcontroller modules soldered onto the daughter boards as well as many non-module microcontrollers.
Support direct power from 2-16V using a newer power supply technology.
Possibly support USB Type-C power as well.
The idea is to have one Uno like clone that supports multiple microprocessors by daughter board and most Arduino shields.
Chris Hamilton
Nikolaj Andersson Nielsen
Gergely Imreh
Makerfabs
Chris K Cockrum
