The payment gateway will support several exchange based wallets utilizing the ccxt library. With that library, we should be able to make an initial MVP that allows to pass wallet and transaction information to donors. The charity should then be able to manually track project goal totals.
We will soon after support a dashboard and project goal information for charities from the exchange APIs.
We hope to support static wallet addresses for cold wallets. To do that fully, we will need to implement blockchain specific reporting systems using client nodes.
Chris Hamilton
Eng. Angel Arturo Ramírez
RT-Thread IoT OS
AdityaPrakash23
Dylan Bleier
Accepting cryptocurrency donations is a great solution for modern charities. It reduces transaction costs, increases transparency, and allows you to attract donors from all over the world.
To set this up, you need a payment gateway that supports cryptocurrencies, has a user-friendly interface, and has tools for tracking donations. For example, https://paykassma.com/ offers easy integration, reliable transaction protection, and convenient reports.
With such a solution, you will simplify the donation process and expand the possibilities of your charity.
