Starting with a fork of the ATTinyTemp enclosure i created a rounded cube enclosure for the blink(inch) in OpenSCAD. It is just a bit larger than an inch^3, and thanks to the original parametric design the only real effort went into making sure the hole for the USB plug was the right size.
spro
