The latest revision of the Analyser has an idle clock function that pops up when the display is otherwise blank.
This uses a GPS connected to RX1 (Pin 0) to provide time and date.
//#define ENABLE_GPSCLOCKUncommenting this line will turn it on.
A project log for Teensy Audio Spectrum Analyser
The Teensy Audio Spectrum Analyzer is a low-cost classic audio spectrum display with up to 128 bands.
