As you can see, I've been fairly busy these last days soldering the prototypes that will be shipped out to the current contributors. The final case is about to be produced, as well as several front panel variations.
Hopefully the call for beta testers will be sent in less than a month. At this moment, we'll ask our assembler to produce everything from A to Z. This implies the two PCBs, the front panel and a few extra bits.
