As you can see in the photo there is a hook on the long end of the spring. This is left over from its former home, it located with something in the CD-ROM mechanism.
It's worth noting though that it's very handy for placing the spring on an SMD component. I simply pick the hook up with the end of a small screwdriver to lift it, much easier than trying to manipulate the spring itself.
Jenny List
