; CIS-261 ; implementation of I/O procedures called by macros in io.obj ; flat memory model version .386 .MODEL FLAT PUBLIC itoaproc, atoiproc, dtoaproc, atodproc, outproc, inproc, szlenproc .CODE ; itoaproc(source, dest) ; convert integer (source) to string of 6 characters at given destination address itoaproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame push eax ; Save registers push ebx ; used by push ecx ; procedure push edx push edi pushf ; save flags mov ax, [ebp+12] ; first parameter (source integer) mov edi, [ebp+8] ; second parameter (dest offset) ifSpecial: cmp ax,8000h ; special case -32,768? jne EndIfSpecial ; if not, then normal case mov BYTE PTR [edi],'-' ; manually put in ASCII codes mov BYTE PTR [edi+1],'3' ; for -32,768 mov BYTE PTR [edi+2],'2' mov BYTE PTR [edi+3],'7' mov BYTE PTR [edi+4],'6' mov BYTE PTR [edi+5],'8' jmp ExitIToA ; done with special case EndIfSpecial: mov dx, ax ; save source number mov al,' ' ; put blanks in mov ecx,5 ; first five cld ; bytes of rep stosb ; destination field mov ax, dx ; copy source number mov cl,' ' ; default sign (blank for +) IfNeg: cmp ax,0 ; check sign of number jge EndIfNeg ; skip if not negative mov cl,'-' ; sign for negative number neg ax ; number in AX now >= 0 EndIfNeg: mov bx,10 ; divisor WhileMore: mov dx,0 ; extend number to doubleword div bx ; divide by 10 add dl,30h ; convert remainder to character mov [edi],dl ; put character in string dec edi ; move forward to next position cmp ax,0 ; check quotient jnz WhileMore ; continue if quotient not zero mov [edi],cl ; insert blank or "-" for sign ExitIToA: popf ; restore flags and registers pop edi pop edx pop ecx pop ebx pop eax pop ebp ret 6 ;exit, discarding parameters itoaproc ENDP ; dtoaproc(source, dest) ; convert double (source) to string of 11 characters at given offset in DS (dest) dtoaproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame push eax ; Save registers push ebx ; used by push ecx ; procedure push edx push edi pushf ; save flags mov eax, [ebp+12] ; first parameter (source double) mov edi, [ebp+8] ; second parameter (dest addr) ifSpecialD: cmp eax,80000000h ; special case -2,147,483,648? jne EndIfSpecialD ; if not, then normal case mov BYTE PTR [edi],'-' ; manually put in ASCII codes mov BYTE PTR [edi+1],'2' ; for -2,147,483,648 mov BYTE PTR [edi+2],'1' mov BYTE PTR [edi+3],'4' mov BYTE PTR [edi+4],'7' mov BYTE PTR [edi+5],'4' mov BYTE PTR [edi+6],'8' mov BYTE PTR [edi+7],'3' mov BYTE PTR [edi+8],'6' mov BYTE PTR [edi+9],'4' mov BYTE PTR [edi+10],'8' jmp ExitDToA ; done with special case EndIfSpecialD: mov edx, eax ; save source number mov al,' ' ; put blanks in mov ecx,10 ; first ten cld ; bytes of rep stosb ; destination field mov eax, edx ; copy source number mov cl,' ' ; default sign (blank for +) IfNegD: cmp eax,0 ; check sign of number jge EndIfNegD ; skip if not negative mov cl,'-' ; sign for negative number neg eax ; number in EAX now >= 0 EndIfNegD: mov ebx,10 ; divisor WhileMoreD: mov edx,0 ; extend number to doubleword div ebx ; divide by 10 add dl,30h ; convert remainder to character mov [edi],dl ; put character in string dec edi ; move forward to next position cmp eax,0 ; check quotient jnz WhileMoreD ; continue if quotient not zero mov [edi],cl ; insert blank or "-" for sign ExitDToA: popf ; restore flags and registers pop edi pop edx pop ecx pop ebx pop eax pop ebp ret 8 ;exit, discarding parameters dtoaproc ENDP ; atoiproc(source) ; Procedure to scan data segment starting at source address, interpreting ; ASCII characters as an integer value which is returned in AX. ; Leading blanks are skipped. A leading - or + sign is acceptable. ; Digit(s) must immediately follow the sign (if any). ; Memory scan is terminated by any non-digit, and the address of ; the terminating character is in ESI. ; The following flags are affected: ; AC is undefined ; PF, SF and ZF reflect sign of number returned in AX. ; CF reset to 0 ; OF set to indicate error. Possible error conditions are: ; - no digits in input ; - value outside range -32,768 to 32,767 ; (AX) will be 0 if OF is set. atoiproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame sub esp, 2 ; local space for sign push ebx ; Save registers push ecx push edx pushf ; save flags mov esi,[ebp+8] ; get parameter (source addr) WhileBlank: cmp BYTE PTR [esi],' ' ; space? jne EndWhileBlank ; exit if not inc esi ; increment character pointer jmp WhileBlank ; and try again EndWhileBlank: mov ax,1 ; default sign multiplier IfPlus: cmp BYTE PTR [esi],'+' ; leading + ? je SkipSign ; if so, skip over IfMinus: cmp BYTE PTR [esi],'-' ; leading - ? jne EndIfSign ; if not, save default + mov ax,-1 ; -1 for minus sign SkipSign: inc esi ; move past sign EndIfSign: mov [ebp-2],ax ; save sign multiplier mov ax,0 ; number being accumulated mov cx,0 ; count of digits so far WhileDigit: cmp BYTE PTR [esi],'0' ; compare next character to '0' jl EndWhileDigit ; not a digit if smaller than '0' cmp BYTE PTR [esi],'9' ; compare to '9' jg EndWhileDigit ; not a digit if bigger than '9' imul ax,10 ; multiply old number by 10 jo overflow ; exit if product too large mov bl,[esi] ; ASCII character to BL and bx,000Fh ; convert to single-digit integer add ax,bx ; add to sum jc overflow ; exit if sum too large inc cx ; increment digit count inc esi ; increment character pointer jmp WhileDigit ; go try next character EndWhileDigit: cmp cx,0 ; no digits? jz overflow ; if so, set overflow error flag ; if value is 8000h and sign is '-', want to return 8000h (-32,768) cmp ax,8000h ; 8000h ? jne TooBig? cmp WORD PTR [ebp-2],-1 ; multiplier -1 ? je ok1 ; if so, return 8000h TooBig?: test ax,ax ; check sign flag jns ok ; will be set if number > 32,767 overflow: pop ax ; get flags or ax,0000100001000100B ; set overflow, zero & parity flags and ax,1111111101111110B ; reset sign and carry flags push ax ; push new flag values mov ax,0 ; return value of zero jmp AToIExit ; quit ok: imul WORD PTR [ebp-2] ; make signed number ok1: popf ; get original flags test ax,ax ; set flags for new number pushf ; save flags AToIExit: popf ; get flags pop edx ; restore registers pop ecx pop ebx mov esp, ebp ; delete local variable space pop ebp ret 4 ; exit, removing parameter atoiproc ENDP ; atodproc(source) ; Procedure to scan data segment starting at source address, interpreting ; ASCII characters as an integer value which is returned in EAX. ; Leading blanks are skipped. A leading - or + sign is acceptable. ; Digit(s) must immediately follow the sign (if any). ; Memory scan is terminated by any non-digit, and the address of ; the terminating character is in ESI. ; The following flags are affected: ; AC is undefined ; PF, SF and ZF reflect sign of number returned in EAX. ; CF reset to 0 ; OF set to indicate error. Possible error conditions are: ; - no digits in input ; - value outside range -2,147,483,648 to 2,147,483,647 ; (EAX) will be 0 if OF is set. atodproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame sub esp, 4 ; local space for sign push ebx ; Save registers push ecx push edx pushf ; save flags mov esi,[ebp+8] ; get parameter (source addr) WhileBlankD:cmp BYTE PTR [esi],' ' ; space? jne EndWhileBlankD ; exit if not inc esi ; increment character pointer jmp WhileBlankD ; and try again EndWhileBlankD: mov eax,1 ; default sign multiplier IfPlusD: cmp BYTE PTR [esi],'+' ; leading + ? je SkipSignD ; if so, skip over IfMinusD: cmp BYTE PTR [esi],'-' ; leading - ? jne EndIfSignD ; if not, save default + mov eax,-1 ; -1 for minus sign SkipSignD: inc esi ; move past sign EndIfSignD: mov [ebp-4],eax ; save sign multiplier mov eax,0 ; number being accumulated mov cx,0 ; count of digits so far WhileDigitD:cmp BYTE PTR [esi],'0' ; compare next character to '0' jl EndWhileDigitD ; not a digit if smaller than '0' cmp BYTE PTR [esi],'9' ; compare to '9' jg EndWhileDigitD ; not a digit if bigger than '9' imul eax,10 ; multiply old number by 10 jo overflowD ; exit if product too large mov bl,[esi] ; ASCII character to BL and ebx,0000000Fh ; convert to single-digit integer add eax,ebx ; add to sum jc overflowD ; exit if sum too large inc cx ; increment digit count inc esi ; increment character pointer jmp WhileDigitD ; go try next character EndWhileDigitD: cmp cx,0 ; no digits? jz overflowD ; if so, set overflow error flag ; if value is 80000000h and sign is '-', want to return 80000000h (-2^32) cmp eax,80000000h ; 80000000h ? jne TooBigD? cmp DWORD PTR [ebp-4],-1 ; multiplier -1 ? je ok1D ; if so, return 8000h TooBigD?: test eax,eax ; check sign flag jns okD ; will be set if number > 2^32 - 1 overflowD: pop ax ; get flags or ax,0000100001000100B ; set overflow, zero & parity flags and ax,1111111101111110B ; reset sign and carry flags push ax ; push new flag values mov eax,0 ; return value of zero jmp AToDExit ; quit okD: imul DWORD PTR [ebp-4] ; make signed number ok1D: popf ; get original flags test eax,eax ; set flags for new number pushf ; save flags AToDExit: popf ; get flags pop edx ; restore registers pop ecx pop ebx mov esp, ebp ; delete local variable space pop ebp ret 4 ; exit, removing parameter atodproc ENDP ; *************** setup for Win32 I/O **************** STD_OUTPUT EQU -11 STD_INPUT EQU -10 GetStdHandle PROTO NEAR32 stdcall, nStdHandle:DWORD ReadFile PROTO NEAR32 stdcall, hFile:DWORD, lpBuffer:NEAR32, nNumberOfCharsToRead:DWORD, lpNumberOfBytesRead:NEAR32, lpOverlapped:NEAR32 WriteFile PROTO NEAR32 stdcall, hFile:DWORD, lpBuffer:NEAR32, nNumberOfCharsToWrite:DWORD, lpNumberOfBytesWritten:NEAR32, lpOverlapped:NEAR32 .DATA written DWORD ? read DWORD ? strAddr DWORD ? strLength DWORD ? hStdOut DWORD ? hStdIn DWORD ? .CODE ; outproc(source) ; Procedure to display null-terminated string ; No registers are changed; flags are not affected. outproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame pushad pushfd ; save flags mov esi,[ebp+8] ; source address mov strAddr, esi ; find string length mov strLength, 0 ; initialize string length WhileChar: cmp BYTE PTR [esi], 0 ; character = null? jz EndWhileChar ; exit if so inc strLength ; increment character count inc esi ; point at next character jmp WhileChar EndWhileChar: INVOKE GetStdHandle, ; get handle for console output STD_OUTPUT mov hStdOut, eax INVOKE WriteFile, hStdOut, ; file handle for screen strAddr, ; address of string strLength, ; length of string NEAR32 PTR written, ; bytes written 0 ; overlapped mode popfd ; restore flags popad ; restore registers pop ebp ret 4 ;exit, discarding parameter outproc ENDP ; inproc(dest,length) ; Procedure to input a string from keyboard. ; The string will be stored at the address given by dest. ; The length parameter gives the size of the user's buffer. It is assumed ; that there will be room for the string and a null byte. ; The string will be terminated by a null character (00h). ; Flags are unchanged. inproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame pushad ; save all registers pushfd ; save flags INVOKE GetStdHandle, ; get handle for console STD_INPUT mov hStdIn, eax mov ecx, [ebp+8] ; string length mov strLength, ecx mov esi, [ebp+12] ; source address mov strAddr, esi INVOKE ReadFile, hStdIn, ; file handle for keyboard strAddr, ; address of string strLength, ; length of string NEAR32 PTR read, ; bytes read 0 ; overlapped mode mov ecx, read ; number of bytes read mov BYTE PTR [esi+ecx-2],0 ; replace CR/LF by trailing null popfd ; restore flags popad ; restore registers pop ebp ret 8 ; exit, discarding parameters inproc ENDP ;ik-10/4/2008 ; szlenproc(source) ; Procedure to calculate length of a null-terminated string ; No registers are changed; flags are not affected. szlenproc PROC NEAR32 push ebp ; save base pointer mov ebp, esp ; establish stack frame pushad pushfd ; save flags mov esi,[ebp+8] ; source address mov strAddr, esi ; find string length mov strLength, 0 ; initialize string length WhileChar: cmp BYTE PTR [esi], 0 ; character = null? jz EndWhileChar ; exit if so inc strLength ; increment character count inc esi ; point at next character jmp WhileChar EndWhileChar: popfd ; restore flags popad ; restore registers pop ebp mov eax, strLength ; rerun string length in EAX ret 4 ;exit, discarding parameter szlenproc ENDP END
This is not my code! This is from http://www.c-jump.com/bcc/c261c/CIS261syllabus.html
