This is a place holder for the LM2596 Buck converter bought on eBay. Basically just an easy way to prototype in Eagle.
The set pin is the 'centre' tap of the pot and it means that I can control the voltage output of the module with an input voltage.
Datasheet is here:
My eagle library is here:
Greg Duckworth
Does anyone know how many times the CH552 can be reprogrammed before it fails?
LM2596 Eagle Library has been updated
404 error. Could you reupload the file? I really need this for a project.
did u get this project?
