Designed and printed a box for the lightronome:
The mounting hardware still need some work, but the device is working now:
There are a few comments to add:
- The mounting hardware still need some work, so you can expect some writing about it
- The two currently used buttons also has remote capability through a 3.5mm Jack. The external buttons drive the internal ones through optocouplers. This is not isolated just there for providing some noise immunity.
- There are place on the board for crystal. I don't know if such precision is required, but I didn't populated yet.
