STEP DOWN UNIT: NOT RECOMMENDED
This step down unit produces a lot of heat even with the fan and heat sinks added
A project log for Power Supply Plan 24 Volts 300Watt heatpad
Power Supply Plan 24 Volts 300Watt heatpad or higher
