"Preliminary" Burner Design
A project log for Smelting Furnace for Aluminium
I am looking to build a oil or gas fired furnace for smelting Aluminium and maybe brass for casting.
tonyTony • 08/29/2016 at 02:11•0 Comments
So lacking any specific dimensions to the type of burner I wanted to build I put pencil to paper and drew some plans. The Burner I wanted to build is based on a Delavan Siphon Nozzle. I liked this because of the clean look and apparent ease of operation. It also will gives me the option of running on waste oil, liquid fuels, or Propane.
I have also assembled a list of components that I will need to build it. For the Preliminary parts list I gathered prices from McMastercarr being as it is a favorite site of mine for general project supplies. The list is also more of a wish list than and actual list and due to the steep price tag I will likely look for cheaper options and suppliers. As a last note I have updated my project notes .doc with this information as well.
http://www.patriot-supply.com/
Delavan Siphon nozzle
Part#30609-8
$24.00
Delavan Nozzle Addapter
Part#17147
$24.00
http://www.mcmaster.com
Feed line
Quantity
Description
Part#
Price
Extended
Air
1
Industrial-Shape Hose Coupling, Size 1/4 Zinc-Plated Steel Plug, 1/4 NPTF Female End
6534K56
$1.32
$1.32
All
4
Steel 37 Degree Flared Tube Fitting, Adapter for 1/4" Tube OD x 1/4 NPTF Male Pipe
50695K162
$1.46
$5.84
All
1
Smooth-Bore Seamless Steel Tubing, 1/4" OD, 0.049" Wall Thickness, 6 Feet Long
9220K321
$10.46
$10.46
Null
1
Standard-Wall Steel Pipe, 2 Pipe Size, 3' Length, Unthreaded
7750K196
$46.45
$46.45
Oil
1
Compact Extreme-Pressure Steel Threaded Fitting, 1/8 Pipe Size, 90 Degree Male Elbow
50925K117
$3.83
$3.83
Oil
1
Steel 37 Degree Flared Tube Fitting, Straight Adapter for 1/4" Tube OD x 1/8 NPTF Female
50695K171
$1.95
$1.95
Oil
1
ISO-A Hose Coupling, Zinc-Plated Sleeve-Lock Socket, 1/4 Coupling, 1/4" NPTF Female
51335K51
$21.94
$21.94
Oil
1
ISO-A Hose Coupling, Zinc-Plated Plug, 1/4 Coupling Size, 1/4" NPTF Female
51335K61
$8.38
$8.38
Oil
1
PVC Tubing for Fuels and Lubricants, 1/4" ID, 3/8" OD, 25 ft. Length
5187K63
$16.25
$16.25
Oil, LP
2
Compact Extreme-Pressure Steel Threaded Fitting, 3/8 Male x 1/4 Female Pipe Size, Hex Head Bushing
50925K345
$1.50
$3.00
Propane
1
Hose Coupling for Natural and LP GAS, Socket, 3/8" NPT Female, 3/8" Coupler
6053T11
$23.25
$23.25
Propane
1
Hose Coupling for Natural and LP GAS, Plug, 3/8" NPTF Female, 3/8" Coupler
6053T12
$11.18
$11.18
Propane
1
Gas Regulator for Propane, CGA #510 Male Inlet, Standard Duty, 1-Stage
7897A66
$141.09
$141.09
Propane
1
12 Feet Long Hose for Torch-to-Propane Tank Adapter
7976A34
$41.46
$41.46
Propane
1
Brass Barbed Tube Fitting for Vacuum, Straight for 1/4" Tube ID x 1/4 Male Pipe Size
44555K132
$3.03
$3.03
Total
$339.43
