Finished main expansion board: IDE and UART!
A project log for Z80 overpowered computer
I am building a computer with a 4MHz Z80, 32KiB EEPROM, 32KiB RAM, IDE interface and UART.
dylan-brophyDylan Brophy 10/28/2016 at 00:190 Comments
I finally finished the expansion board. Its the same size as the main board but is focused on interface with other hardware and peripherals. These include IDE hard/disk drives and UART. The UART is for interfacing with my Open Source Graphics Card and for easier programming of the EEPROM. The graphics card is another project you should check out. I will be testing my new hardware when I make a EEPROM programmer and can really test my programs.
