Alternate uses
A project log for DYPLED
a thin LED display in SIP module format, much better than TIL311s to visualise your computer buses
yann-guidon-ygdesYann Guidon / YGDES • 01/26/2016 at 05:43•0 Comments
Displaying a bus value (address and/or data) is nice, but I have been suggested other uses, such as time display (think: clock) or multimeter display (volts, amperes, ohms, whatever). What else would you do with a DYPLED module ?
Edit (20160413)
The #SPDT16: 16-bits arithmetic unit with relays would need 3 or 4 #DYPLED
It would also be used in the #Quick & Dirty Frequency Generator to show the division factor and/or the actual frequency...
