Not a failure but not a success either
A project log for DYPLED
a thin LED display in SIP module format, much better than TIL311s to visualise your computer buses
yann-guidon-ygdesYann Guidon / YGDES • 08/28/2016 at 05:30•2 Comments
I received the latest PCB batch with the first DYPLED boards, and the issues are explained in this page.
I don't think I can make the modules work completely as expected, mainly because of the unmasked vias that will create shorts with the thermal pads of the 4014 LEDS.
At least I can validate other aspects of the module, such as the push-buttons, the PWM, solderability, etc.
20160902: I tried to solder the first LED (when there is no via under them) and the result is pretty good, soldering is not hard (not easy but I didn't experience any difficulty). At least I don't have to change the footprints :-)
Time to test the other circuits !
Ted Yapo wrote 09/02/2016 at 01:06 • point
Yann, do you think you can trust soldermask to prevent shorts even when the boards get produced correctly?  I am facing a similar issue with different LEDs that have a thermal slug underneath, and was considering solid soldermask and silkscreen under them for insulation, since I want to run traces there.  I could be sure with a little kapton tape, but I'm wondering that the best practices are.
I like the look of those displays!
Yann Guidon / YGDES wrote 09/02/2016 at 01:15 • point
I think I can trust the soldermask. At worst, I can repair the eventual, occasional gotcha. The issue I can envision is the tiny bumps of the tracks but it's negligible.
And thanks, I am proud of this design, which I made also for others to use and enjoy :-) You'll tell me if you want one when the first working units will be made (we'll see what we can trade ;-) )
