Particular cabinet for arcade video games that can be assembled without screws or nails, all simply by clamping the various parts. It can be made of plywood, MDF or printed with 3D printer.
The size of the cabinet allows you to use a 7 or 10-inch monitor, while as commands it is predisposed to use a joystick and six buttons for the games. On the sides of the cabinet are available holes for installing speakers with 70 mm diameter, Credit and Start button. In the posterior part of cabinet are available the power outlet, USB port, HDMI port for an external monitor, power-on / off switch. As a video game emulator, Raspberry Pi can be used (recommended, given the number of resources available for this application) or more.
