Problem A: Infrastructure
- U.S. infrastructure is currently rated as subpar and is continuously degrading (Graded D+ by ASCE)
- Part of the issue lies in the extreme costs of repairs necessary across the nation (estimated $4.59 billion by 2025 to fix)
- This massive increase in spending would cause a drag on the economy ($3.9 trillion GDP loss by 2025)
- Too many problems, too expensive, takes too long
Problem B: Disaster Relief Management
- Disasters are difficult to recover from and each disaster has unique requirements and problems that need to be addressed
- Disasters are inherently unpredictable and so disaster preparation would require addressing all possible problems before it occurs, a prospect that can be prohibitively expensive
- It’s also expensive to be reactionary and ship required relief materials for every disaster only after the disaster has occurred
- Loss of life is worse immediately following the disaster before the relief supplies can make it to their destination
- Massive, repeated shipments can be problematic due to bureaucratic and logistical delays
Problem C: Construction and Landscaping
- Building homes and structures is expensive and time consuming
- Machines for construction are expensive and have high specialization sometimes requiring many different machines for a single project
- Cheaper, mass produced materials result in low levels of customization and customer satisfaction also requiring expensive shipment to the destination
- Heavy earth moving machinery is often needed for landscaping projects which can be expensive or difficult to acquire
- Using heavy machinery can be difficult and requires additional skills; alternatively hiring professionals only makes the work more expensive
Problem D: Non-Terrestrial Construction
- Sending up satellites is limiting in both space and weight
- After the heavy costs associated with initial construction, there are currently no options for repairs in the case of damage
- Space junk is a problem without a good method of deorbiting debris
- Expensive and restrictive to need to send all materials to construct a habitat on another planet
- Materials to build habitats exist on planets but no machines currently capable of utilizing them or constructing habitats
Solution
- Teleoperated robots!
- Remote operated requiring skilled workers or semi-autonomous task completion
- Perform checking and eventually construction that’s more cost effective
- Makes workers more efficient and amplifies their capabilities
- Increase in safety with cheap, expendable robots performing dangerous work
- Flexible function using modular attachments means each robot is capable of many different actions
- Small size means robots can work concurrently in the same location, reducing multiple phases of a project into a single, incremental step
- Swarm methodology for a group of robots means tasks can be accomplished much quicker
- A combination of a large swarm and the modularity means specific tasks can be dynamically allocated due to shifting requirements
Goals
Tier 1
- Robot with modular attachments that enable it to serve various functions
- Cheap base model that can be produced in quantity and has basic motion, communication, and sensor capabilities
- Assignable roles so that broken robots can easily be replaced by spare units or units can be re-assigned based on need
- Teleoperation with visual data so that users can get direct feedback about the status of the project’s target
- Limited physical intervention required by users
- Ability to direct movement and basics tasks to be performed by the robots
Tier 2
- Modular attachments can be swapped autonomously
- Dynamic role allocation so that the robots automatically determine the best distribution to get a task done efficiently
- Coordinated motion so the robots can be given simple direction to accomplish group behavior
Tier 3
- Machine learning can automatically flag problematic inspection data
- Augmented reality data so that the users can see the project target and the current progress side by side
- Advanced autonomy with the robots having the capabilities to perform a great deal of tasks with little user control required
Specifications
Sensors
- Camera for teleoperation and visual data collection
- GPS
- IMU
- Attachment identification
Communication
- Central communication node to route mesh network packets
- Master node compiles debug information and swarm state
- Master establishes swarm requirements and passes them on to individual agents
- Handled over WiFi with the master node providing the central access point
User Interface
- Communication through a web interface hosted on the central node
- Accessible by connecting to the swarm network
- High level control abilities to direct general motion of the group and assign tasks
- Lower level control also available for finer motion control
- Individual robots are selectable so that debug information, robot state, and individual command interfaces are available
Job Allocation
- Jobs are dynamically allocated and passed on to the individual robots via communication with the master node
- Robots automatically connect to the attachments required to perform their assigned tasks
Potential Attachments
- Gripper: Movement of structural material
- Dumper: Transportation and removal of debris, earth, sand, etc.
- Arm: Fine manipulation of objects
- Screwdriver
- Drill
Milestones
1. First Functional Prototype
- Single robotic unit
- Direct control basic interface (command line, GPS coordinates, etc.)
- Basic motion and movement commands with low accuracy
2. Attachment Prototypes
- Several basic, modular attachments for the prototype robot so it can perform various functions (e.g. gripper, arm, digger, screwdriver, drill, material transportation)
- Automatic identification and control of the different attachments
3. Prototype Swarm
- Multiple units controllable via a single interface
- Different attachments to show multi-use cooperation
- Direct control basic interface for individual units as well as group movements
- Central communication hub to route communication between robots and provide single access point that distributes commands to individual swarm members
4. Survey and Analysis Demo
- Demonstration of basic survey capabilities using direct control interface and teleoperated swarm
- Robots coordinate with each other to map out a structure and provide detailed pictures
- Optional additional sensors for measuring other useful data (e.g. radiation, temperature, vibration)
5. Repair Demo
- Demonstration of basic repair capabilities using direct control interface and teleoperated swarm
- Robots are capable of moving repair materials into place and performing the repairs without physical operator intervention
- Robots can cooperate as a cohesive group to transfer repair materials and/or remove broken material
6. Construction Demo
- Demonstration of basic construction capabilities using direct control interface and teleoperated swarm
- Robots are capable of assembling an entirely new structure without physical operator intervention
- Robots are capable of working together to prepare construction area and build a structure
