I think the next thing I'm going to work on will be SPI / netboot
I'm going to start with a newly compiled uboot on the SD card to get netbooting working, then I will transfer that working uboot to the SPI flash, cant wait to be done flashing and reading sd cards all day.
The results of that are this correctly configured fex though (opi one), use fex2bin and replace /boot/script.bin
this gets rid of the asic CPU set errors, but it also sets the CPU to a constant speed (which is ok with me), and fixes USB issues
--------------UPDATE-----------------
I was just told that the site malformed this file, DO NOT COPY/PASTE THIS
I will post the file in the files section
[product]
version = "100"
machine = "Xunlong Orange Pi One"
[platform]
debug_mode = 1
eraseflag = 1
next_work = 2
[target]
boot_clock = 1008
storage_type = -1
[key_detect_en]
keyen_flag = 0
[fel_key]
fel_key_max = 7
fel_key_min = 2
[card_boot]
logical_start = 40960
sprite_work_delay = 500
sprite_err_delay = 200
sprite_gpio0 = port:PL10<1><default><default><default>
next_work = 3
[box_start_os]
used = 1
start_type = 1
irkey_used = 1
pmukey_used = 1
pmukey_num = 3
led_power = 0
led_state = 0
[boot_init_gpio]
used = 1
gpio0 = port:PL10<1><default><default><1>
gpio1 = port:PG11<1><default><default><1>
[recovery_para]
used = 1
mode = 2
recovery_key = port:PL04<0><default><default><default>
[pm_para]
standby_mode = 1
[card0_boot_para]
card_ctrl = 0
card_high_speed = 1
card_line = 4
sdc_d1 = port:PF00<2><1><2><default>
sdc_d0 = port:PF01<2><1><2><default>
sdc_clk = port:PF02<2><1><2><default>
sdc_cmd = port:PF03<2><1><2><default>
sdc_d3 = port:PF04<2><1><2><default>
sdc_d2 = port:PF05<2><1><2><default>
[card2_boot_para]
card_ctrl = 2
card_high_speed = 1
card_line = 8
sdc_cmd = port:PC06<3><1><2><default>
sdc_clk = port:PC05<3><1><2><default>
sdc_d0 = port:PC08<3><1><2><default>
sdc_d1 = port:PC09<3><1><2><default>
sdc_d2 = port:PC10<3><1><2><default>
sdc_d3 = port:PC11<3><1><2><default>
sdc_d4 = port:PC12<3><1><2><default>
sdc_d5 = port:PC13<3><1><2><default>
sdc_d6 = port:PC14<3><1><2><default>
sdc_d7 = port:PC15<3><1><2><default>
sdc_2xmode = 1
sdc_ddrmode = 1
[twi_para]
twi_port = 0
twi_scl = port:PA11<2><default><default><default>
twi_sda = port:PA12<2><default><default><default>
[uart_para]
uart_debug_port = 0
uart_debug_tx = port:PA04<2><1><default><default>
uart_debug_rx = port:PA05<2><1><default><default>
[force_uart_para]
force_uart_port = 0
force_uart_tx = port:PF02<3><1><default><default>
force_uart_rx = port:PF04<3><1><default><default>
[jtag_para]
jtag_enable = 0
jtag_ms = port:PA00<3><default><default><default>
jtag_ck = port:PA01<3><default><default><default>
jtag_do = port:PA02<3><default><default><default>
jtag_di = port:PA03<3><default><default><default>
[clock]
pll_video = 297
pll_ve = 402
pll_periph0 = 600
pll_gpu = 576
pll_periph1 = 600
pll_de = 864
[dram_para]
dram_clk = 624
dram_type = 3
dram_zq = 0x3b3bfb
dram_odt_en = 1
dram_para1 = 283377664
dram_para2 = 0
dram_mr0 = 6208
dram_mr1 = 64
dram_mr2 = 24
dram_mr3 = 2
dram_tpr0 = 0x48a192
dram_tpr1 = 0x1c2418d
dram_tpr2 = 0x76051
dram_tpr3 = 0x0
dram_tpr4 = 0x0
dram_tpr5 = 0x0
dram_tpr6 = 0x64
dram_tpr7 = 0x0
dram_tpr8 = 0x0
dram_tpr9 = 0x0
dram_tpr10 = 0x0
dram_tpr11 = 0x6aaa0000
dram_tpr12 = 0x7979
dram_tpr13 = 0x800800
[wakeup_src_para]
cpu_en = 0
cpu_freq = 48
pll_ratio = 273
dram_selfresh_en = 1
dram_freq = 36
wakeup_src0 =
wakeup_src_wl = port:PG10<4><default><default><0>
wakeup_src_bt = port:PL03<6><default><default><0>
[twi0]
twi_used = 1
[twi1]
twi_used = 1
twi_scl = port:PA18<3><default><default><default>
twi_sda = port:PA19<3><default><default><default>
[twi2]
twi_used = 0
twi_scl = port:PE12<3><default><default><default>
twi_sda = port:PE13<3><default><default><default>
[uart0]
uart_used = 1
uart_port = 0
uart_type = 2
uart_tx = port:PA04<2><1><default><default>
uart_rx = port:PA05<2><1><default><default>
[uart1]
uart_used = 0
uart_port = 1
uart_type = 4
uart_tx = port:PG06<2><1><default><default>
uart_rx = port:PG07<2><1><default><default>
uart_rts = port:PG08<2><1><default><default>
uart_cts = port:PG09<2><1><default><default>
[uart2]
uart_used = 0
uart_port = 2
uart_type = 4
uart_tx = port:PA00<2><1><default><default>
uart_rx = port:PA01<2><1><default><default>
uart_rts = port:PA02<2><1><default><default>
uart_cts = port:PA03<2><1><default><default>
[uart3]
uart_used = 0
uart_port = 3
uart_type = 4
uart_tx = port:PA13<3><1><default><default>
uart_rx = port:PA14<3><1><default><default>
uart_rts = port:PA15<3><1><default><default>
uart_cts = port:PA16<3><1><default><default>
[spi0]
spi_used = 1
spi_cs_bitmap = 1
spi_mosi = port:PC00<3><default><default><default>
spi_miso = port:PC01<3><default><default><default>
spi_sclk = port:PC02<3><default><default><default>
spi_cs0 = port:PC03<3><1><default><default>
[spi1]
spi_used = 0
spi_cs_bitmap = 1
spi_cs0 = port:PA13<2><1><default><default>
spi_sclk = port:PA14<2><default><default><default>
spi_mosi = port:PA15<2><default><default><default>
spi_miso = port:PA16<2><default><default><default>
[spi_devices]
spi_dev_num = 1
[spi_board0]
modalias = "spidev"
max_speed_hz = 33000000
bus_num = 0
chip_select = 0
mode = 0
full_duplex = 1
manual_cs = 0
[gpio_para]
gpio_used = 0
gpio_num = 0
[leds_para]
leds_used = 1
green_led = port:PL10<1><default><default><1>
green_led_active_low = 0
red_led = port:PA15<1><default><default><0>
red_led_active_low = 0
[ths_para]
ths_used = 1
ths_trip1_count = 6
ths_trip1_0 = 75
ths_trip1_1 = 80
ths_trip1_2 = 85
ths_trip1_3 = 90
ths_trip1_4 = 95
ths_trip1_5 = 105
ths_trip1_6 = 0
ths_trip1_7 = 0
ths_trip1_0_min = 0
ths_trip1_0_max = 1
ths_trip1_1_min = 1
ths_trip1_1_max = 2
ths_trip1_2_min = 2
ths_trip1_2_max = 3
ths_trip1_3_min = 3
ths_trip1_3_max = 4
ths_trip1_4_min = 4
ths_trip1_4_max = 8
ths_trip1_5_min = 8
ths_trip1_5_max = 8
ths_trip1_6_min = 0
ths_trip1_6_max = 0
ths_trip2_count = 1
ths_trip2_0 = 105
[cooler_table]
cooler_count = 1
cooler0 = "1200000 4 4294967295 0"
[nand0_para]
nand_support_2ch = 0
nand0_used = 0
nand0_we = port:PC00<2><default><default><default>
nand0_ale = port:PC01<2><default><default><default>
nand0_cle = port:PC02<2><default><default><default>
nand0_ce1 = port:PC03<2><default><default><default>
nand0_ce0 = port:PC04<2><default><default><default>
nand0_nre = port:PC05<2><default><default><default>
nand0_rb0 = port:PC06<2><default><default><default>
nand0_rb1 = port:PC07<2><default><default><default>
nand0_d0 = port:PC08<2><default><default><default>
nand0_d1 = port:PC09<2><default><default><default>
nand0_d2 = port:PC10<2><default><default><default>
nand0_d3 = port:PC11<2><default><default><default>
nand0_d4 = port:PC12<2><default><default><default>
nand0_d5 = port:PC13<2><default><default><default>
nand0_d6 = port:PC14<2><default><default><default>
nand0_d7 = port:PC15<2><default><default><default>
nand0_ndqs = port:PC16<2><default><default><default>
[boot_disp]
advert_disp = 0
auto_hpd = 1
output_type = 4
hdmi_channel = 0
hdmi_mode = 4
cvbs_channel = 1
cvbs_mode = 11
output_full = 1
hdmi_mode_check = 1
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 3
screen0_output_mode = 5
screen1_output_type = 3
screen1_output_mode = 5
fb0_format = 0
fb0_width = 0
fb0_height = 0
fb1_format = 0
fb1_width = 0
fb1_height = 0
[hdmi_para]
hdmi_used = 1
hdmi_power = "vcc-hdmi-18"
[tv_para]
tv_used = 1
tv_dac_used = 1
tv_dac_src0 = 0
[pwm0_para]
pwm_used = 0
pwm_positive = port:PA05<3><0><default><default>
[gmac0]
gmac_used = 2
gmac_power1 =
[csi0]
vip_used = 1
vip_mode = 0
vip_dev_qty = 1
vip_define_sensor_list = 0
vip_csi_pck = port:PE00<2><default><default><default>
vip_csi_mck = port:PE01<2><default><default><default>
vip_csi_hsync = port:PE02<2><default><default><default>
vip_csi_vsync = port:PE03<2><default><default><default>
vip_csi_d0 = port:PE04<2><default><default><default>
vip_csi_d1 = port:PE05<2><default><default><default>
vip_csi_d2 = port:PE06<2><default><default><default>
vip_csi_d3 = port:PE07<2><default><default><default>
vip_csi_d4 = port:PE08<2><default><default><default>
vip_csi_d5 = port:PE09<2><default><default><default>
vip_csi_d6 = port:PE10<2><default><default><default>
vip_csi_d7 = port:PE11<2><default><default><default>
vip_csi_sck = port:PE12<2><default><default><default>
vip_csi_sda = port:PE13<2><default><default><default>
vip_dev0_mname = "gc2035"
vip_dev0_pos = "front"
vip_dev0_lane = 1
vip_dev0_twi_id = 2
vip_dev0_twi_addr = 120
vip_dev0_isp_used = 0
vip_dev0_fmt = 0
vip_dev0_stby_mode = 0
vip_dev0_vflip = 1
vip_dev0_hflip = 1
vip_dev0_iovdd = ""
vip_dev0_iovdd_vol = 2800000
vip_dev0_avdd = ""
vip_dev0_avdd_vol = 2800000
vip_dev0_dvdd = ""
vip_dev0_dvdd_vol = 1800000
vip_dev0_afvdd = ""
vip_dev0_afvdd_vol = 2800000
vip_dev0_power_en = port:PA17<1><default><default><1>
vip_dev0_reset = port:PE14<1><default><default><1>
vip_dev0_pwdn = port:PE15<1><default><default><0>
vip_dev0_flash_en =
vip_dev0_flash_mode =
vip_dev0_af_pwdn =
vip_dev0_act_used = 0
vip_dev0_act_name = "ad5820_act"
vip_dev0_act_slave = 24
vip_dev1_mname = ""
vip_dev1_pos = "rear"
vip_dev1_lane = 1
vip_dev1_twi_id = 0
vip_dev1_twi_addr =
vip_dev1_isp_used = 0
vip_dev1_fmt = 1
vip_dev1_stby_mode = 0
vip_dev1_vflip = 0
vip_dev1_hflip = 0
vip_dev1_iovdd = ""
vip_dev1_iovdd_vol = 2800000
vip_dev1_avdd = ""
vip_dev1_avdd_vol = 2800000
vip_dev1_dvdd = ""
vip_dev1_dvdd_vol = 1500000
vip_dev1_afvdd = ""
vip_dev1_afvdd_vol = 2800000
vip_dev1_power_en =
vip_dev1_reset =
vip_dev1_pwdn =
vip_dev1_flash_en =
vip_dev1_flash_mode =
vip_dev1_af_pwdn =
[tvout_para]
tvout_used = 0
tvout_channel_num =
tv_en = 0
[tvin_para]
tvin_used = 0
tvin_channel_num =
[di_para]
di_used = 1
[mmc0_para]
sdc_used = 1
sdc_detmode = 3
sdc_buswidth = 4
sdc_det = port:PF06<0><1><2><default>
sdc_use_wp = 0
sdc_wp =
sdc_isio = 0
sdc_regulator = "none"
sdc_power_supply = "none"
[mmc1_para]
sdc_used = 1
sdc_detmode = 4
sdc_buswidth = 4
sdc_clk = port:PG00<2><1><3><default>
sdc_cmd = port:PG01<2><1><3><default>
sdc_d0 = port:PG02<2><1><3><default>
sdc_d1 = port:PG03<2><1><3><default>
sdc_d2 = port:PG04<2><1><3><default>
sdc_d3 = port:PG05<2><1><3><default>
sdc_det =
sdc_use_wp = 0
sdc_wp =
sdc_isio = 1
sdc_2xmode = 1
sdc_ddrmode = 1
[mmc2_para]
sdc_used = 0
sdc_detmode = 3
sdc_buswidth = 8
emmc_rst = port:PC16<3><1><2><default>
sdc_det =
sdc_use_wp = 0
sdc_wp =
sdc_isio = 0
sdc_2xmode = 1
sdc_ddrmode = 1
[smc_para]
smc_used = 0
smc_rst = port:PA09<2><default><default><default>
smc_vppen = port:PA20<3><default><default><default>
smc_vppp = port:PA21<3><default><default><default>
smc_det = port:PA10<2><default><default><default>
smc_vccen = port:PA06<2><default><default><default>
smc_sck = port:PA07<2><default><default><default>
smc_sda = port:PA08<2><default><default><default>
[usbc0]
usb_used = 1
usb_port_type = 2
usb_detect_type = 0
usb_id_gpio = port:PG12<0><1><default><default>
usb_det_vbus_gpio = port:PG12<0><1><default><default>
usb_drv_vbus_gpio = port:PL02<1><0><default><0>
usb_host_init_state = 1
usb_restrict_gpio =
usb_restric_flag = 0
usb_restric_voltage = 3550000
usb_restric_capacity = 5
usb_regulator_io = "nocare"
usb_regulator_vol = 0
usb_not_suspend = 0
[usbc1]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_not_suspend = 0
[usbc2]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_not_suspend = 0
[usbc3]
usb_used = 1
usb_drv_vbus_gpio =
usb_restrict_gpio =
usb_host_init_state = 0
usb_not_suspend = 0
[usb_feature]
vendor_id = 6353
mass_storage_id = 1
adb_id = 2
manufacturer_name = "USB Developer"
product_name = "Android"
serial_number = "20080411"
[msc_feature]
vendor_name = "USB 2.0"
product_name = "USB Flash Driver"
release = 100
luns = 3
[serial_feature]
serial_unique = 0
[module_para]
module_num = 7
module_power0 = "vcc-wifi-33"
module_power0_vol = 0
module_power1 =
module_power1_vol =
module_power2 =
module_power2_vol =
module_power3 =
module_power3_vol =
chip_en =
lpo_use_apclk =
[wifi_para]
wifi_used = 1
wifi_sdc_id = 1
wifi_usbc_id = 2
wifi_usbc_type = 1
wl_reg_on = port:PL07<1><default><default><0>
wl_host_wake = port:PG10<0><default><default><0>
wl_host_wake_invert = 0
[bt_para]
bt_used = 0
bt_
