Started off with which display would work the best in in a vehicle environment which needed to be a serial display. Searching the net I found the best option for me at Seetron.com. The OLED display works with very low and very high temps, much better than LCD units. I then took 4 days straight to learn how to code the splash screen display seen here.
My co-worker Doug is very smart with code and explained very well to me what I need to do and ways to write it. After capturing and displaying the main data I wanted to view which was Gear position and automatic/manual mode, I am now working on viewing other info such as MPH and Throttle position.
Once I figure out how to only display the values I want and exclude the other characters that pass into the display when the controller changes gear then I will hopefully be successful with attaching the other serial outputs from my other controllers to the Arduino to read other useful vehicle info which helps with tuning the car.
turbofreaktuning
peter ward
Alexander
