Eventually I submit one product for Tindie.com (at this moment, I am not sure it will be admitted or not..) and it is a kit requires full assembly and I guess relatively good soldering skill and experience is required. (I think most of hackaday.com people have excellent soldering skill, though)
So here I would show how to solder SMT in quick and clean manner.
Step1: Put enough solder on electrode.
Step 2: Remove solder by de-solder braid
Not all of solder but most solder should be removed. Residue will work as glue!
Step 3: Carefully align chip and gently push every electrode
Alignment is quite important but your hand will be enough good tool. Just gently push by soldering iron is enough to connect. No additional solder is needed. If you have some concern, add small amount of solder for each electrode.
Complete! Have fun!
